Getting a general “vibration” when I hit about 50-55 mph. Gets worse for a bit when I let off the gas. If I hit the gas again it gets a little better. Only happens around 50.
1985 442 only has about 67000 miles on it. Engine has about 1000. Trans 2500.
I have replaced the body bushings and have the Jeep steering shaft. Since the vibration started I also replaced the entire front suspension, and trans mount.
U joints about 7500 miles old. But I wondering if this could be driveshaft/u joint related. Stock driveshaft. Weights are still there. Any thoughts or similar experiences would be great. Thanks.
