Here are the specs and build of my motor. It has about 10:1 compression. I'm thinking 325HP/350Tq???? Thanks!
Engine chevy 350 .060 over
eagle crank, rods, speed pro pistons, sealed power rings
clevite 77 bearings
comp cams cam 270h, 270 duration, 470 lift
comp cams lifters, hardened one piece push rods
pete jackson noisey gear drive
melling oil pump, oil drive
arp main studs, head bolts, rod bolts
Chevy double hump heads casting 3890462 dates D207 (April 20, 1967) and D217 (April 21, 1967), ported, polished, 2.02I, 1.60E, hardened seats, screw in studs, guide plates
harland sharp roller rockers 1.5
summit stage 3 intake (edelbrock rpm air gap)
barry grant speed demon 650 electric choke, vacuum secondaries
clevite 77 bearings
