The wiring on the passenger's side is a mixture of two separate harnesses. The computer harness comes out of the firewall on the passenger's side underneath the HVAC box. The computer harness and the main ignition/charging/A/C harness is one of the two harnesses that plug into the main bulkhead connector under the wiper motor. It plugs into the harness that the blower motor and it's ancillaries plug in to. That is a 4 wire plug and it is universal to all engines except maybe turbo or diesel applications, so you can just reuse your original there. So, the harnesses in the engine bay are as follows: Computer, main engine, Cruise Control ( comes out of a grommeted hole right of the steering column that is only drilled in cars so equipped), lighting and minor A/C harness. You only need the main harness for a swap that does not include the computer. When pulling your harness however, be sure it is complete and factory with no spliced in wires or crimp connectors that GM did not supply. Also, if possible, try to get one with the steel tube that acts as a heat shield for the starter wires still intact. This protects them from the exhaust system.
