Any difference in G-Body & Grand Cherokee 800 steering boxes?
454GrandPrix
429
818
Lehi, Utah
My 605 steering box leak has gone from a small drip to nearly a steady stream, so I need to replace it immediately. I've decided to forego the junkyard route and buy a new (reman) 800 unit. Just for kicks, I have been searching the local parts stores for two gear boxes: one for an '87 Monte Carlo SS w/Z65 Sport pkg, and one for a '95 Grand Cherokee. Not surprisingly, the pricing is pretty consistent across the board.
Something I noticed: at every store, the Monte Carlo box is about $20 cheaper than the Grand Cherokee box. All the threads indicate these boxes are interchangeable, though they carry different part numbers and I cannot figure out what the difference(s) might be. Is there any reason to pony up for the Jeep gearbox? Or will I be just as content with the Monte Carlo unit?
I'm looking to get the ball rolling on this ASAP, so any comments/experience would be greatly appreciated.
timo22
550
1,072
St. Louis,Mo
If the boxes come with the pitman arm, get the Monte box. If they do not include the pitman arm, you will need to get a 800 box pitman arm. The 605 pitman arm will not work on an 800 box. timo22
  • Informative
oldsmobile joe
2,067
3,053
mpls
the only difference i know of is the amount of rotation travel in the pitman arm shaft. the monte is spec'ed at 78.5 degrees and the jeep is spec'ed at 87.5 degrees. that means, with the jeep box, you'll have a smaller, tighter turning radius, but your tires may rub near full steering wheel lock.
joe
454GrandPrix
429
818
Lehi, Utah
I do recall reading that, so I am prepared to get one of those also.
Awesome--that's exactly what I needed to know.
Thanks, gang.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Would it be possible for someone to create a sticky with all the pertinent info, please?
I'm good on concept, but lost on details (operating pressures, pitman arm interchangability, fitting styles, etc...)
78chevolds
126
50
I agree. My 605 in my 78 Cutlass is leaking bad. I was thinking of getting the Camaro/Trans Am box from Rock Auto that has the quicker ratios. I compared the connections to my Camaro and it should bolt up. I was thinking getting a new pitman arm but order that for a 350 Cutlass. I was going to use the existing power steering pump and new hoses from that pump to the new box
HAFROD
2,179
3,331
Claremore, OKLAHOMA
A Cherokee unit with pitman from a U pull it style yard would be a really inexpensive route. If your 30+ year old unit is just now recently leaking, the used unit could probably get you a few years of leak free service. I did a seal kit in one of my steering boxes and I think it was under $20 for the kit. My local O'Reilley could not get me another Monte SS box. It showed unavailable in their system for a 1986 Monte Carlo SS. So basically, I got their last one. It leaks out the front case and I tried re sealing it twice. It now sits in the garage in the box. I may do the Cherokee box from my local U pull it yard on my future Century turbo project
