Any guesses on HP for this 403
Csilvy2000
251
87
Texarkana, AR
I put together an Olds 403 for my '79 Supreme. Wondering if anyone would care to take a stab on what type of horsepower and torque this motor is making. Here's the combo.
1977 model 403
Stock heads with a resurface, light home porting, stock valves, heat riser holes filled in.
Stock pistons and bores, put a rering kit in it with new bearings, std. crank and rods
Running an Edelbrock Performer RPM intake, Demon 650 carb, Cheap ebay HEI distributor
Longtube headers with 1 5/8" primaries.
I'm running the generic camshaft that has .442 lift on the intake and .472 lift on the exhaust (or vice versa, I don't remember the exact numbers on the cam, but its a very common Olds swap cam.)
I also added the fully adjustable rocker arm setup made by Comp Cams. Had to use some custom sized pushrods, but it was worth it.
I think the stock numbers on this engine were around 180 HP and maybe 300 lb-ft of torque.
Only thing the engine is turning are an alternator and a water pump.
Car runs good, but I'm still using the th200 and the 2.29 rear gear.
Any guesstimates?
Turbolq4
1,732
4,207
Nampa Idaho
270/385 flywheel.
Edit:-100 from each for pitiful compression ratio and no flow heads.
84 W40
581
793
230/350 at the crank
Csilvy2000
251
87
Texarkana, AR
Thanks for the input. I'll put her on the track and see which guess is the closest. I was thinking 222/325. Car pulls good from 2500 to 4500. Those 2.29 make that 2000 rpm spread last a WHILE.
foxtrot
1,489
590
USA
In my mind are a few things that you need to do to get a ton of horsepower out of the 403… The first thing is you really need to raise the compression to something greater than 9 to 1. A good cam and good flow thru the heads will also help.
Csilvy2000
251
87
Texarkana, AR
I'm thinking my compression is closer to 8:1. I didn't shave the heads and I used a stock fel-pro head gasket. I knew that would be an issue with this build. The 403 was a budget build and I really enjoyed putting the old Olds together. That was my first Olds motor. Next up, I've got a 455 waiting on the back burner. I've put together several SBC's and when money comes into consideration, It's hard to dig into an old Oldsmobile. They ain't cheap.
Mike T
112
133
Baton Rouge, LA
If you want to take the time to get me some specs., I can run the numbers through my computer dyno program and give you some numbers that should be close to real time. If you do, let me know and I'll give you a list of what i need.
  • Friendly
Csilvy2000
251
87
Texarkana, AR
Yeah Mike, let's do that. I don't have the software and sure don't have access to a dyno. Shoot me a list. Appreciate it.
