I was checking the doors and notice the inner and outer window felts need to be changed,
I was looking on how to remove the outer window felt but it looks as if
it's attached to the bottom wide molding 2pc that runs along the top of the door. I've been looking online for the set
inner and outer both sides, but I see there's 2 styles. One's a wide chrome and then there's a narrow chrome. Also is
is there molding clips holding this molding on the door? What type of clip ? Any tricks on removing this molding ? Any input would be helpful on which ones I should buy and how should I go about doing this? I have all new door weather striping as well and figured if I'm dooring the weather striping I'll change the window felt too.
Thanks, Rob
Thanks, Rob
