Anyone Ever Hear Of This Guy ?
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
Those pods look pretty trick. Is the A pillar different on the wagon compared to the other models?
I know there is a full A pillar with 3 gauge openings. I want to say gbodyparts has them, I know I've seen them on ebay.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Other than the wagon and coupe A-pillars being different, the angle is different as well. The coupe or El Camino A-pillars are more angled than the wagon or 4-dr sedan which are a bit more upright.
  • Informative
565bbchevy
9,611
12,670
Michigan
I bought one of those full 3 gauge A pillars a few years back and sent it back, it didn't have the outer edge that wraps around where the window seal is which could be seen from the outside of the car, it looked unfinished and was flimsy. I ended up using a 2 pod and mounting it to my original piece.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
Good to know! I was curious about the full pillar pod. Mine are all in the dash as you most likely have seen, but back in the day I had the dual pod seen in this throwback pic lol.....
565bbchevy
9,611
12,670
Michigan
Good to know! I was curious about the full pillar pod. Mine are all in the dash as you most likely have seen, but back in the day I had the dual pod seen in this throwback pic lol..... View attachment 78252
My original plan was to put the nitrous fuel and line pressure gauges in the back of cowl hood opening but Autometer advised against it if there was a possibility of them being exposed to water or moisture so I went with the pillar pod and then wired the lighting for them on a separate toggle switch.
