Thanks Chris, I would appreciate that. My MOTOR manual only gave the lift and that did not jive with any Pontiac cam I know of. What it is, is that I have a '76 455 out of said Bonneville. Totally stock. It is sitting in my '68 Firebird convertible with a ST-10 4 speed just so it can move under it's own power. I need to know what cam came in it so I can make an intelligent decision going forward. The stock cam may be what I want for a nice cruiser/boat towing motor. I have several Crane cams I can use too. Maybe it will end up in my Bonnewagon. I am in the process of stripping and scrapping my '77 TA due to rust worms. Once that is gone the '68 comes home. That will probably be my last old car project and I am trying to decide on what motor to use. I have the 455, the '77 TA 400, a '68 400 HO, a '70 GTO 400, several 301's and an '80 Turbo 301. The '68 400 HO/RA would be period correct and a lot of fun. I have 2 sets of the factory long branch exhaust manifolds. I have a '67 4 pinion posi rear but that is for mono-leaf springs. I also have a '79 TA disc rear that has been modified to fit the '68 and still retain the factory double traction bars that came on '67 HO/RA cars. And then again a Turbo 301 with a 4 speed stick may be perfect for a light front end/ good handling car. Lots of time to think about it but first I need to know what cam is in there because it is the only unknown factor. edit-[ Kennybill, the Edelbrock Performer is just an aluminum copy of the very good stock Pontiac cast iron manifold. The RPM is a step up]
