yes i think your right on both countsLooks like a proportioning valve on the left. Not sure on the other one. Under hood light?
yeah, you can probably see it from above depending on what's going on in the engine compartment. brass/cast iron(?) rectangle thing with a few lines going in it. if your brake light is on, that is why. it's not plugged in. it comes on when there's a break in the circuit (i think), or when one of the lines on the front or rear burst (or a wheel cylinder), and the internal piston moves to one side and it trips the light.
