Just remember that you could break it and loose your axles and land on your quarter panelsThat rear end works too as long as you don't have too much HP to break it.
And if you do, you can always swap it out.
For certain i'd get a rise out of that rear end.... but not really cost prohibitive in the long run.
this^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ is the rear
Auto is much more suttle on the drivetrain. The manual stuff tends to beat everything to pieces.Well after reading through this thread, I'm a lot more comfortable with my factory 7.5 Posi unit (freeway gears for now) in my '79 Malibu. I have the Blueprint 383 in mine and while it's 450 HP @ 6000 RPM's I'll never take it there. It's just a fun car to enjoy. The mildly built TH350 trans and rear gears will eventually be switched but I get enough enjoyment from it either way. If anything was to break with the trans or rear end then it will get moved up the list. Until then, I'm just gonna enjoy it.
Not sure, probably wouldn't be able to tell until you "pop the cover" and get in there and root around. But I'm betting it's sturdy, high quality, and wouldn't be cheap. Make sure you use the proper lube.Rachel Stuhlmann (@rstuhlmann) • Instagram photos and videos
179K Followers, 260 Following, 153 Posts - See Instagram photos and videos from Rachel Stuhlmann (@rstuhlmann)www.instagram.com
is that a Quick Performance or a Strange Engineering built rear?
