Remove the A/C system inside & the exterior Evap case off the firewall in the engine compartment (outside). Install the 'Heat Only' conversion kit (or just the engine compartment firewall panel) where the original parts were. Where these cases mount, they attach thru factory holes on the firewall.Does this cover simply go onto the hvac case mounting or do you remove the car, split your hvac case, install the heater only cover and then reinstall the whole case?
