CUTLASS Anyone used these trim rings on factory 15” painted ralley wheel?
old80cs
old80cs
225
Massachusetts
I found these listed on Speedway Motors, I need a pair for my 15” Ralleys on the back of my Cutlass Supreme. Are they of good quality or should I keep looking for OEM trim rings?
B
Bitterman
153
I have used them on my 15" rallies. Do not try and install them right out of the box. Take a pair of pliers and bent the metal tabs in a little bit. I tried to install one right out of the box and it gouged the paint on the rim and was a nightmare to get on. After I learned that, the rest installed nicely.
old80cs
old80cs
225
Massachusetts
View attachment 135423 View attachment 135424
Did you use the 3” or 2” depth? I’m thinking the 3” but just want to be sure before I order a pair of them. Thanks.
B
Bitterman
153
I will have to check tonight when I return home. I believe I used the 3 inch, but I'll confirm later tonight
Reactions: old80cs
B
Bitterman
153
This is what I ordered from speedway. Item 9101976 GM 15" 3" deep stainless steel beauty ring.
