GBOTM April '20 ENTRIES - Mad Fabrication Skillz
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,509
4,903
Rolla, MO
recommended by our March winner...
How about vehicles utilizing the most innovative mods/upgrades? The members here have some crazy fabrication skills. Always nice to see stuff like that being showcased.
So, if you have pix of you doing some furious cutting/welding/etc. , let's see them. Maybe a little vague but you get the idea.
Go!
I'll run entries for 4 days or until we have 8-10 entries more or less.
...and I know this was supposed to get posted Saturday night when I got back. Putting out fires since then basically. Ugh.)
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Reactions: 6 users
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Alright I'll try for this one. What pics do you want?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
i got the winning video but too bad it wasn't recorded. There is no one more furious than me when a welding job doesn't turn out and then I turn in a madman with the grinder. The reason why there are no recordings is no one will get close enough to shoot one.... :popcorn:
Reactions: 6 users
81cutlass
4,649
13,565
Western MN
My type of fabrication usually involves a lathe or a mill!
Such as
Welding 7.5 axle tubes onto an 8.5 and fabbing an UCA bracket
Cutting down stock rotors for LS1 front brakes
Cutting down 15X6 pontiac ralleys to make 15X4 front runners
Mount a GT500 blower to a LS Maggie intake and make my own fuel rails
Fab GT500 blower to LS2 TB adapter
I'll stop there. Literally a good portion of the reason I build cars is just to play around with fab work. :)
  • Winner
Reactions: 15 users
macgyver49
7
8
06 LS into a beater 87 el camino I'm using as a test bed. then when I get all the things figured out, it will go into my white 85.
so far its been amazing, fast and great mileage. been driving it for a couple weeks now.
most expensive thing besides the wrecked $1200 06 chevy 1/2 ton silverado was the $200 driveshaft shortening .everything else was $20 to $50
it just dropped into place moving the motor mounts back into the next set of holes.
stock intake, stock truck pan and all the a/c parts. stock truck fuel pump into the modified stock el camino tank, with the stock fuel sending unit mounted to the truck fuel pump housing. no return line or pressure regulator. even got the cruise to work with stock turn signal lever.
  • Indifferent
Reactions: 4 users
Sundancer
166
229
Long Island, NY
Wow, all you guys are absolutely madmen and I mean that in the best way ! I envy you :) :banana:
