are walmart batteries any good?
cherokeechief79
102
15
nj
I need to get a new batt for my 84 monte.the one at walmart is around 75 bux and the autozone one is about 115.are the walmart ones any good?it still has a 3 yr replacement and 2 yr pro rate after that.
also what would be the highest cold crank amp one I could fit in the stock location?i know im limited because of the side terminals.
UNGN
3,048
3,264
Southlake, TX
No batteries are good, anymore.
Walmart neverstart batteries are cheap, Walmarts are everywhere and the replacement is hassle free (none of the "we'll put it on a charger and check it... come back in 3 hours" crap).
Its where I get most of my batteries, now.
UNGN
3,048
3,264
Southlake, TX
The factory batteries are 75's but a 78 will usually fit with a G-body without much modding. Probably can't go much bigger than that.
Walmart sells N and S batteries (North and South). The N batteries have the most CCA's.
A 78N is 800 CCA vs. 700 in a 75N.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
A car I bought had one in it.
Never had an issue with it.
But I never seen a dual post version which is what I like to run.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Is there an Interstate battery distributor anywhere near you?. I have used their rebuilt batteries in my winter rides and never had a problem with them. I get them for under $50 and it comes with a warranty
TURNA
Jul 24, 2009
10,941
19,990
Socialist NY
Just called my local distributor 49.99 for a 78 series with trade in 65 without.
Great deal!!!!!
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,501
4,849
Rolla, MO
eh yeah been using them too. they probably all come from the same two factories anyway.
Awesomeaj
25
Michigan
GP403 is right, they all come from the same two factories. If you have a Sam's Club near you, you can get the same batteries for a little lower price.
