I have had my gauges apart oh say five times so far. Good news I got the oil pressure gauge to work and installed new LED lights.........BUT
I followed a repair video on the GBody You tube and I soldered a wire between the center post and the V8 post on the tach leads.
with the initail reinsertion of the gauges I turn the key to ON and the tach needle jumps to sero. I start the car and the tach reads maybe
1000 rpms on a fast idle. Yabba Dabba DO.........
NOW IS WHERE THE PROBLEM STARTS
When I shut the car off, the tach will stay at say 500-600 rpms. I turn the key back to start and it stays at it's previous read 500 or 600 and DOES NOT go back to zero.
When I start the car again the car's tach's reading goes up from there. So while idling at say 800 rpms (ThX Everyday Performance) the tach now reads 1200 or 1300.
Shut the car off, tach goes back maybe to 800. Then next start, it now goes to maybe 1500 instead of being at 800.
Any ideas as to WHY it does this? And I am trying to keep the gauge cluster working and in tack, or is that in TACH? Yes factory gauges
suck and blah blah blah but I'd like to know a real fix rather than opinions of factory gauges. Could the needle be sticking? IS there a
resistor that may be going bad?
