astro steering shaft and steering pump noise
RobM
Nov 2, 2016
66
Ozone Park Kid
I installed an astro steering shaft today and the steering is so much tighter. I have a question
about the steering pump, it makes noise now. When I make a turn, I can hear noise from the steering
pump. It sounds like air rushing in though the steering column when I turn left or right.
I open the hood with the car running and turned the steering shaft by hand. I heard
the same noise coming from the steering pump.
Do you think maybe the steering pump is going. I never had this problem, until
I installed the astro steering shaft today.
Thanks for your time and help,
Rob
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
change the power steering fluid and make sure the system is bled...
Ribbedroof
4,891
6,941
Wellston, OK
Now you know why the rag joint is in the original setup.....
