Re: Astro Van Engine Swap
I did a '95 a few years ago. If you (and the owner) don't mind cutting the core support at the top of the radiator opening, you can pull the engine out the front. This allows you to not disturb the cradle (steering, suspension, brake system, etc.). When you are done you can weld or bolt (as I did) the section back in. IIRC the air box and duct work even covered one of the splices. I know it may sound like hackery but it shaves about 6 hours off the engine R&R -- if you are well equipped. If you are working in a driveway -- forget it.
