At my wits end with this QuadraJet
Rktpwrd
Builder of Cool Shjt
4,165
23,911
Calgary, Alberta, Canada
Anybody able to answer the question if the engine is able to run on the primary circuit rather than the idle circuit?
I can’t see any other explanation for why I have to rev it that high to get it to stay running.
Oct 14, 2008
8,818
7,763
Melville,Saskatchewan
I think that is exactly why it won't run until you get into the primary circuit. I think mine also would barely idle and my base timing needed cranked way up which contributed to pinging.
Rktpwrd
4,165
23,911
Thanks for the insight. Maybe I’ll have to look into enlarging the idle orfice restrictions...???
I have the timing advanced for the best power, but there’s no signs of detonation. Don’t recall offhand what the final total timing number is now anymore, but it spins over without too much trouble and makes good power.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
I have no input besides
Everyday Performance just built me a Qjet and the price with a core was excellent!!!!
lilbowtie
3,460
3,965
Canton Mi
I hate giving any advice on carb problems because there are so many variables. To answer your question you can be on the primary circuit, the throttle blades should show no more than .040 of the transfer slot in the closed position. Your idle screws should be 1 and a 1/2 turns out
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
if it won't idle and it's running pig rich I would take the carburetor apart and start over making sure you are using the correct gaskets and make sure the float level is correct. If you changed the primary rods make sure you didn't mistakenly use a rods from a 74 and down version of the quadrajet.
8,818
7,763
As said the rods aren't interchangeable between Qjet series. I am betting the carb is ridiculously lean at idle for his motor. Donovan, what do you think the compression ratio is approximately? Cliff Ruggles shows the modifying the idle tubes and drilling out and the passages at the mixture screws as well in his book. Do you remember what jets an rods were in it? A sinking float messes can cause all sorts of issues but that was tested and set.
Texas82GP
Just-a-worm
Apr 3, 2015
7,986
18,691
Spring, Texas
Donovan,
How did the car run with this carb before the rebuild?
HAFROD
2,179
3,331
Claremore, OKLAHOMA
