There’s some awesome info flowing now guys, thanks!!
Thanks for the info, it’s proving to be invaluable. I just pulled my carb back off and compared the underside of it to your pic, mine definitely does not have the bypass air ports you pointed out:
So now what does that mean? I’m I screwed already before I even get started?
Again, I’m not certain on the CR, it’s just a half educated guess at this point. My estimate is only a point higher than what that 350 would have come with stock, with the steel shim head gaskets and the smaller combustion chamber volume of the Vortec heads, I don’t think my guess is too far out to lunch.
Thanks for the info. I’m trying to determine the number of turns mine are at right now, but I seem to have lost my adjusting tool!
Great info here, thank you!
So just to be sure before I just start drilling larger holes in my carburetor, what I’m going to be drilling is the existing holes underneath where the idle mixture screws are currently located?
And there doesn’t appear to be any bypass holes to enlarge...
You’re right Christian, turning them past a certain point seems to have little to no effect.
