Audi Flipper
Dayzedandkonfuzed
971
1,268
Anglemont, BC
Picked up an Audi yesterday, 2002 A6 Quattro 2.7t (twin turbo.) Looking just to flip it, the guy figured it needed a crank position sensor. After some research I found out that these can just start working again. The guy was in love with this car, and I knew if I cranked it and it started it would have been game over for me. It was cheap enough that if it needed something far worse I wouldn't be too butt hurt. So I took a chance, looked it over, and pushed it 2 blocks to my buddys place after giving him a figure in the 3 digit region. Crank it over and sure enough it sounds like a weak craftsman drill. Obviously no compression, pretty obvious it had a timing belt go right when he last shut it off or tried to start it up. Audi forums tell me that there is a .0000001% chance that it didn't bend valves, and with 5 valves (yes, 5) per cylinder on an interference engine, I assumed the same.
I don't think there's any other potential problem to cause low/no compression across the board, but it is german so who knows...
Anyway, has anyone worked on one of these? Should I bother trying to fix this or just flog it off? Sounds like the valves are soft and don't typically damage the pistons, at least in this situation, so probably just a belt and head swap
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Ha! My neighbor's bf's kid YouTubed his was through a timing belt change. I told him to turn it over by hand first. He didn't listen, hit the starter, and crashed the valves into the pistons. There is a neat trick to drop the whole nose, though.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
Yea these jobs that look daunting aren't usually as bad as they seem, because the manufacturers know this will be the only way to fix something that will inevitably break. Its like the newish super duty trucks, sure you gotta pull the cab off just to put an air freshener in, but I hear they come off really easy, well as long as you have a hoist.
DRIVEN
8,074
14,533
*CENSORED*
I'd probably pedal it as-is. I've done timing belts on them but not head replacement. The problem with VWs and Audis is that there's ALWAYS something else wong. Never could make good money on them.
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,509
4,903
Rolla, MO
1 RARE T
282
434
Sell it immediately!
Audi owners are douche bags.
KCP
421
1,004
Bavaria, Germany
Check the timing first. If it runs, the belt is still on might have only slipped by one tooth.
Those V6's are good for half a million miles when maintained right.
8,823
7,775
Melville,Saskatchewan
Yeah, a great idea considering Navistar followed the tried and true Olds 350 diesel😣, using 4 head bolts per cylinder along with boost in their 6/6.4L garbage motors. Yeah interference motors suck, got to love timing belts too, yet another reason I dumped my 2010 3.5 Challenger. Not that there isn't issues with chains. Using dual, self adjusting tensioners with prestrecthed German chain helps. Took GM and Ford awhile to get it right on their DOHC 6, my Pentastar thankfully seems to have it figured out from the get go. It does sound like a neat little car, probably fast. Wow 5 valves per cylinder sounds insane, leave it to the Germans.
