GBOTM August Entries - BOP/Cad Engine Swaps
GP403
Administrator
Site Admin
Feb 25, 2005
4,509
4,900
Rolla, MO
The original suggestion from billyjack for a theme for August was "diesel swaps" i.e. removing the questionable Olds diesels and replacing it with something else, but I think that's probably way too small a cross section...
So, instead, I'll go for BOP/Cad Engine swaps. Or even anything that IS NOT either a Chevrolet (SB or BB) or LS engine of any variety. That should open it up while still keeping it a little tight. Meaning the engine you PUT IN not what you took out. Doesn't really matter what it was before the swap.
I'll leave this open until we get about 7-8 entries or it gets to be 3 days on. All the usual rules apply. Obviously we need to see that engine.
And go!!
fauxfour2
156
278
1984 Cutlass Brougham with a 403 out of a 79 Trans Am and a 200-4r out of an 86 442. Still getting her dialed in but shes mine and makes me happy. According to Gateway classics it is worth $328,000 USD... lol I kidd I kidd!
Reactions: 17 users
Rus
283
858
Queensbury, NY
1979 Buick Sport Coupe, Pontiac 400 4v, 200-4r , 3.73 . Car has one of a kind 170 speedometer and custom tachometer. Also has rare 3 piece aluminium bumpers and aluminum radiator support. Motor has comp cam, ram air III manifolds, edelbrock intake and 4 inch cowl hood.
  • Love
Reactions: 18 users
dr78442
731
912
massapequa park NY
78 Olds cutlass .Olds 455 ,5 speed , 8.5 with 3.73 gears
  • Love
Reactions: 14 users
oldsmobile joe
2,067
3,053
mpls
My 79 cutlass calais that i bought and swapped in an olds 455 19 years ago. It now has a 6spd in front of an 8.5" rear with 3.42 posi. It stops with c5 front brakes and ls1 rear brakes. I daily this car all summer with a working a/c. My favorite part is the 120 mph speedo that i bought in 1988 and used in my first calais.
Reactions: 16 users
-dw-
208
377
Central MN
84 Supreme I pulled out of a junkyard back in 98 for 150$. Rod knockin V6 was scrapped and a 750 qjet 9.5-1 455 Olds put in its place. Headers are abody bbo. Slush box is a 700r4. 3.42 posi in an abody 8.5 axle in the back. 34mm fbody swaybar in the front and blazer rear swaybar. Astro van spindles and rotors up front and S10 disc in the rear. Has ran 12.0 in the 1/4. Small cam and quiet mufflers is sounds like a grandmas car.
Trip to the local 1/8 this last sunday.
Reactions: 14 users
Tuffregal83
639
1,150
Lockport, Il
mclellan83
4,238
9,397
Pgh, PA
10,563
14,293
I LOVE THEM ALL!!!!
Rus
283
858
Queensbury, NY
Love the speedo and tach wish I had those for my wagon
I can get you the lead for speedometer being recalibrated and re faced. The tach takes some extra work but same company will put new face on clock piece and you add the tach.
