autometer fuel gauge
1979elcamino
8
Vancouver Island
so i've installed all new gauges and all of them work except the fuel gauge. what's happening is it won't read past half it it reads backwards... i've got a good knowledge of 12vdc systems and i've installed a brand new painless harness so all the wires are marked. i've got the gauge properly grouded to a chassis ground, the fuel tank is full and before i call autometer i figured maybe i can look for some help here.
adumb
490
16
Western, NY
did you install a new sending unit?
if the ohm range on the gauge is different from the ohm range on the sending unit it will not read correct.
i know that sunpro fuel gauges operate on a 240 ohm - 29 ohm range. the stock sending unit operates from 0 - 90 ohms.
see what the ohm range is on the fuel gauge. you may need to match it with a new sending unit.
