Autometer oil pressure line length????'s
dickeymoore
924
Atlanta,Georgia
What length oil pressure line will fit on a G Body mounting the gauge under the radio bezel from the engine block will 3 ft do or will i have to use 6ft
Oct 14, 2008
8,822
7,773
Melville,Saskatchewan
You can get 3,4,5 and 6ft lengths. I had a 4 foot braided, it barely reached the front of the block in basically the same spot.
Oct 14, 2008
8,822
7,773
Front, the sender is behind the water pump on the Olds V8.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
I doubt 3 ft will work
Figure it under the radio up to the speedo cable hole back over to the distributor area
3 feet sounds long until you make a couple of bends and turns
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
https://www.harborfreight.com/1-8-eighth-inch-to-1-1-8-eighth-inch-tubing-cutter-92878.html
565bbchevy
9,613
12,680
Michigan
so I guess the six feet will do
If you are using a copper line then go with 6' and you can either cut it or loop it to make it work, if you were going with braided line then you would want to get it close to the length you need without being too short. Either will work fine.
