Axle bushing installation ?
houston_t
146
108
Metro Detroit
Is there a tool I can rent to install bushings in the axle ears ? I called and asked Oreilly’s but they said they don’t carry anything.
What’s your preferred method ?
oldsmobile joe
2,067
3,053
mpls
69hurstolds
8,195
17,596
$59.99 plus shipping and you get your own Hotchkis removal/install tool.
If that doesn't work, try this: :LOL:
bracketchev1221
1,412
1,647
Put the bushings in the freezer overnight and heat the ear up. Then you have a minute or 2 to tap them in as far as they can go. Otherwise a gear puller with a big socket can press them in .
carnutjw
621
1,465
houston_t
146
108
Metro Detroit
abbey castro
1,048
1,318
Harker Hts TX
my home-made tool. will need to make two as the heat generated will soften the plastic.
xylorex
305
395
New Orleans, LA
I think I used a 2-1/4 socket, 1/2" allthread/nuts/washers pressed the bushing into the socket.
The assembly was similar to Abbey's post above
