B-Body rear swap kits are now listed on the Southside Machine Performance website.
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Interesting.
L67ss
1,350
420
At that price it'd only be worthwhile if you already had the rear
malibudave
204
227
Houston, TX
The square B-bodies seem to have the same axle width as the 73-77 A-body cars. The rough axle flange to axle flange width is 61.5" to 61.78" depending on the aftermarket axle lengths.
G-bodies show and axle flange to axle flange of 57.875" to 58" in width.
The square B-body/ 73-77 A-body rear is roughly 1.5" wider than a G-body.
I am not sure if the lower and upper arm pick up points are the same between the A-body and B-body rear.
Macguyver
GBodyForum Sponsor
Mar 21, 2017
292
458
Looks like a stock lower control arm would work if you did not want to upgrade to tubular and polyurethane. It's using stock style lower control arms stock G-Body sway bar would be used. 8 inch wheel with 5.5 backspace would be perfect.
