Backlit gauges
MechMan
337
139
Kingsport, TN
I was wondering if anyone made stock looking gauges that are backlit or is my only option to use brighter bulbs for the 83-88 Monte Carlo SS?. The ones for the factory are very dim and I want to keep the factory look.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If you can find the GE Nighthawk or the Sylvania Silverstar 194 bulb that will brighten up your gauges
MechMan
337
139
Kingsport, TN
I am looking at the vendor NVU. Anyone use them to make custom gauges?
MechMan
337
139
Kingsport, TN
How bad is the LED brightness? On these cars I never turned it down due to it being so dim.
565bbchevy
9,591
12,612
Michigan
I have found with led dash lights you can find a brightness you like by trying different designs of the same bulb even though you might not be able to adjust it with a switch.
In my Monte with Autometer gauges and my Regal with stock dash I used the same style led bulb 5 SMD 194 and then used a different style that was not as bright for my trio gauges in my Regal
87monteSSMN
Nov 20, 2018
74
24
8
I used blacklight LEDs. Something different to try. Illuminates all orange with neon glow.
