Edit: this thread has morphed into other than bad gas but if you're interested in the saga, read on
We went to put gas in the wagon with LT1 engine. It was close to empty. It ran perfect on the way to the gas station. We put in $50 of 93 octane. Literally 15 seconds after starting it back up it developed a stumble. It continued to stumble on the way home and got gradually worse.
Did some typical diagnostic work to rule other things out and couldn’t find anything wrong. Took a sample in a glass jar and compared it to other 93 octane I had and the suspected bad gas was slightly more yellowish in color. Drained all the gas out of the wagon tank. Took a risk and put 5 gallons of the suspected bad gas in my transit work van with 4 cylinder engine. It was low on gas too. It took the gas and ran fine with no missing of any kind.
Went and got 5 gallons of 93 octane from a different gas station and put it in the wagon. I need to run it longer to be sure but had to come in for the evening. Ill run it more tomorrow. Anyway, the wagon LT1 ran good again with this other gas, at least initially.
Is it possible that the suspected bad gas was “borderline” and the LT1 didnt like it but the 4 banger transit had no problem with it?
