Balancer bolt???'s
69hurstolds
8,195
17,595
You mean the center bolt? Just a dab of oil on the threads is all I've ever done. If you torque it right it won't fall out.
bracketchev1221
1,410
1,647
I use loctite and on the big blocks actually put silicone on the washer to seal it to the balancer in case the oil tries to find its way down the keyway. This is how we built them at the engine shop.
CopperNick
3,357
3,018
Canada
B-Bracket, first locktite red or blue? Second, still apply the correct torque??
dickeymoore
924
Atlanta,Georgia
My old bolt will not screw all the way in I put a socket and rachet on it and it tighten up but its not flush should i continue to tighten the bolt with a bigger rachet or what?Thanks
