I know i need to run the starter wire and alt wire ( which i mounted a distrubution block on the fire wall then i only have one wire to the trunk) but the ground on the inner fender and alt bracket, when i put the battery in the trunk do i just run a ground to the frame and thats it or do i need one from the block to the frame also. And whats the purpose of the ground on the fender? And yes i have an inline fuse.
