Im in the process of doing this now. Using 2/0 welding cable running my hot straight to a kill switch under the car, then up to the glovebox where I have my junction point. Then from there I have a 2/0 cable going through a hole I drilled in the trans tunnel to the starter. I could have used the factory hole in the firewall but I didn't want wires in the engine bay and this way the cable is farther away from my headers and ultimately shorter than if I went the other route.
For ground I ran a 2/0 cable from the battery to the frame, from the battery to the body, from the engine to the frame, and from the engine to the firewall. Can never have too many grounds.
The alternator wire I ran a 4 or 6 gauge cable from the alternator stud to the junction point in the glovebox.
I was going to use a remote solenoid but I don't think it's needed honestly. I bought heavily insulated cable, used wire loom and clips to keep them off of everything, and used insulating heat sleeves for the cable running to the starter.
I used this for distribution point. I love the fact that I can add smaller wires to it easily without having to find 3/8" stud connectors for smaller 14-22 gauge wires.
https://www.summitracing.com/parts/prf-80114
I should add that for the connectors on all of the cabling I used solder lugs instead of crimping and the thickest heat shrink insulation I could find.
