Batwing oil pan
Odd thing to pick a fight about.
I’m the easiest going guy you could meet, all I asked was if someone tried one. He said it would hit the cross member, which I would take as gospel, if he actually had any experience
there are other ways to see if it will fits and he was only trying to help. If you don't want to try to figure it out with the diagrams he found and took his time to post least you could have done is to say thanks. ... 🙄
I did say thanks, it’s really my fault anyway every couple years I completely forget that forums are viper pits for angry/bored/unsatisfiedsensitive people to lurk, sorry to all for my ignorance.
And like I said I will post if it fits so this thread has some info with actual experience
or mods delete this thread and my account if you want
  • Disagree
Reactions: oldsmobile joe
I did say thanks
thanks for adding more misinformation to the the all ready cloudy subject
you have an odd way of showing your appreciation.
now, to answer your question to the best of my abilities, MAYBE.
YOU DIDN'T PROVIDE us with more info on your swap. i.e., types of motor mounts, location of engine, etc, might help. it will fit, but will require crossmember modification. i have seen pictures of "f" body pans fitting, but most of the cross member needs to be removed with the remainder being heavily reinforced. the bat wing pan sump is very similar and will require similar mods.
You joined Dec 2018 and have posted 6 times so I don't think you have any basis for your insulting opinion about this forum
if you had used the search bar you would have come up with this
I said forums
You guys are currently proving the basis for this one.
Look through those links in the search there is no confirmed results. Unless you are going to answer my question in my first post with at least some knowledge of the subject, find the door.
And to the other guy (olds joe)who said I needed to list my setup, I didn’t ask if it would fit my car, I asked if anyone used one in a g body. Pretty straight forward question. Also why do I need to show appreciation to someone who basically lied to me. Please move on be angry/defend people who answer questions they have no knowledge of somewhere else.
if one of you have a unbiased person near you have them read this thread real quick and see if they can see where I peed in all of your candy *ss cheerios.
  • Disagree
