Bearing Part number(s)
Jim Larkin
23
Looking for some help. I am having a hard time finding the part number for Timken bearings and seals for a 86' 442 rear, both axle bearings. (8.5") I do not need the repair bearing / seal. I don't want junk bearing part numbers, please, Timken or equivalent. It seems most part catalogs are only offering the 7.5 rear, not the 8.5 I have.
Jim Larkin
23
Axle bearings, have pinion
Jim Larkin
23
Ok got them. Thanks
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I'm late for the party but I think you will find the axle bearings for the 26 spline is the same as the 28 spline
Rktpwrd
Builder of Cool Shjt
4,155
23,832
Calgary, Alberta, Canada
Jim Larkin
23
I am a bit anal on some of the parts I use, due to many years of experience. That being the case, the part numbers are all Timken, but the numbers cross reference across most brands. The part numbers are for the 28 spline axles, and are for the 8.5" rear. Not sure if the numbers interchange to the 7.5" rear of 26 spline axles. Axle (wheel) bearings are 5707, axle seals are 8660s, and the pinion seal is 2043.
  • Winner
