I have an "80 Malibu with the 305 SBC in it. Last summer I swapped the front accessory belt drive setup from an '81 Cutlass parts car that I had here (also a 305, both non A/C cars), because the alternator belt came off the original belt setup, and the car overheated. On the original setup, only the alternator belt went around the fan pulley. On the Cutlass setup, both the alternator belt, and the power steering belt went around the fan pulley, so I figured it would give me some extra insurance, in case the alternator belt failed again. At that time, I also replaced the water pump with an aftermarket replacement pump, and I put new belts on it. Now, when the engine is cold, I have a squeal type noise when I rev the engine up (sounds just like a belt squeal), but the noise goes away when the engine warms up. Once it cools down a bit, the noise is back. I've adjusted the belts several times, and tried lubing the belts-the noise is still there. Have I missed something? The belts appear to be aligned properly. Should I try belts from another supplier? Maybe something wrong with the water pump? I'm not sure what this is. Any help is greatly appreciated, thanks.
