CUTLASS Bench seat question
Bitterman
230
190
I'm working on a 1980 cutlass. This car origionally had bucket seats with center console. Seats were junk when I got the car and console was worse. I have a bench seat in my basement that should bolt right in but my question is this. Will the center console mounts get in the way of the bench seat sliding when installed?
I also have a steering column that I can swap in to make it a column shift.
I'm trying to get this car on the road without buying bucket seats and with parts I have.
Please advise and happy Christmas eve.
Doug Chahoy
2,565
2,662
Take the console mounts off, put the bench in. If it fits and the floor shift functions ok leave it like that till you can replace the ( more desirable) buckets and console.
Bitterman
230
190
Thanks. I'm curious if I need to remove the mounts for the seat to slide? I'd like to leave them in if they will not be in the way of the seat moving
Doug Chahoy
2,565
2,662
Are they welded in or bolted? I went the other way with my car. It had a bench and I installed buckets and console. Can you post a pic of these brackets?
oldsmobile joe
2,067
3,053
mpls
if you don't get an answer, you'll have to try it your self.
if the seat hits the console mounts, you may be able to shim with seat up with washers. not only can you do this at the floor mounts, but also where the seat attaches to the seat tracks.
if you need to remove the console mounts, i recommend using a spot weld cutting drill bit. they work great and don't mess up the mounts for future use.
Bitterman
230
190
I don't currently have a pic but the mounts are welded in from the factory. The shim idea to clear the mount could work if needed. I am removing the floor shifter and console for this car so the bench will not hit the shifter.
