Best 1 piece oil pan gasket???'s
dickeymoore
924
Atlanta,Georgia
I'm installing a milodon 30700 stock style oil pan on my sbc 406 and would like to know what's the best 1 piece oil pan gaskets and oil pan bolts, part numbers helpful? THANKS
melloelky
4,161
9,568
mass
buy the one from milodon that matches that pan.that way there's no question
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I use studs instead of bolts,....if you ever have to drop the pan with the engine installed you'll be glad you did
Kwik_Cutty88
1,173
662
Coastal North Carolina
I agree with consulting with Milodon for the gasket they recommend. However, I used a 1 piece gasket from Fel-Pro (the blue one) and had great luck. It hasn't even started seeping after 6 years.
Reactions: 4 users
melloelky
4,161
9,568
mass
i struck out using the pan studs from milodon,with my milodon pan.the nuts hit the pan in most areas aside from the corners..that's rite,the pan,gasket and studs from the same manufacture and it wouldn't work...i used them to get it all aligned and replaced them one by one with bolts..
565bbchevy
9,614
12,683
Michigan
I used Allstar studs, Summit 7 quart pan and Fel Pro 1 piece pan gasket and everything worked well together on my Regal SBC
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Felpro in my big block going on 10 years now I wish they made them for all the engines
bracketchev1221
1,411
1,647
I agree with the fel pro recommendation, but check with Milodon what year engines the pan is for. Chevy did something silly in the early 80's I think where they changed the front pan depth and it used a different thickness front seal between the pan and timing cover.
Gonzo1970
898
1,302
Studs
FelPro
That's what I've done in the past.. always good results.
-Gonz
