Best engine assembly lube?
fastNYsix
102
147
The GM EOS worked great for me.
  • Love
8,819
7,766
Yes, I am priming the motor with my Dewalt corded drill and 5/16" socket before start up.
  • Love
John Wm. Zick
Drag Racer Forever !!!
100
71
Winter Haven, Florida
Yeah, Permatex is the most affordable but their stuff is hit and miss. I saw Redline, Lucas, Comp etc. Lubriplate is one I wonder about as in any grease in a motor, will it gob up somewhere it shouldn't? I will prime the motor before start up. Spent a fortune on this motor, not looking to save $5, if one if better than another. The first oil change will literally be just a few miles with fresh non synthetic nothing special our brand Coop10W30 SN oil. Then either a Wix or K+N filter swapped with fresh oil to remove any assembly lube or shaving and dirt that might be missed. Having a roller cam is going to be awesome with nice tight clearances. Any 10W30 and no worries of a flat cam, I been down that road. At least it destroyed a $150 short block, not 5 grand like this one.
I agree with all the above plus ........... I ALWAYS flood the engine with oil by spinning the oil pump until I see it coming out of the push rods. Good luck on your build!!! JZ
John Wm. Zick
100
71
I have used Lubriplate which is essentially white lithium grease.
The main purpose of assembly lube is to supply film thickness until the oil system can splash oil everything.
A lot of marketing hype goes into assembly lube but I am not sure how much it really helps as it gets washed off in the first 10 seconds once oil flows and flushes it out of the bearings.
Moly in the lube is a good thing but again, once it gets washed out it's not doing much
You want it to be sticky/high viscosity so it doesn't fall off the cam or bearing journals before you prime the system and turn it over
But beyond that I haven't seen a scientific explanation to why it helps or matters.
After using a moly based assembly lube, I use Schaeffer Oil because they are the only American oil Co. that adds enough moly to replace zinc which is a sacrificial product. Now there is a German based co. that also has a moly based oil .... LIQUI-MOLY.
8,819
7,766
I have heard good things about Schaeffer oils. I really like that I will be able to use any oil I want with this roller cam.
  • Love
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
I've used this twice, for cam, bearings, lifters and seals with whatever oil I was using for the pistons. It stays on parts FOREVER, we use lubriplate at work and it does not last long if you don't fire up soon (like 3 months tops).
  • Love
Havasutom
37
13
Lake Havasu City, AZ
I was fortunate enough to have a father in law that was a chemical engineer in the oil business. He always recommended Torco engine assembly lube and told me that it was used by most of the NHRA teams he consulted with. I have used it exclusively in all my engines and never had a problem.
  • Happy
