Best front tubular control arms?
Silent viewer
1,445
142
I am looking at all of the different brands of control arms and wondering if there is any advantage of one or the other? Spohn is on the top of my list right now for the lowers, Is there any reason that the QA1, UMI or any other is any better? For front uppers I have heard the speedway arms (or similar) are bang for buck, Is there any downfall to using those? ball joint angles?? Does the SC&C upper arms being fully adjustable do anything that I will notice over a non adjustable? Planning to run tall ball joints on upper and lower with blazer sealed hub spindles.
buzz77
304
60
I got the Spohn lowers. But havent installed them yet. They look great and I think are the best bang for the buck. I had them install .5 taller lbj's on them for 60 bucks extra.
melloelky
4,152
9,532
mass
i think a lot of times it depends on what you're looking to get from an aftermarket control arm,if you're just after something that has a certain look without any geometry change/gain then the market is full of them.they're just copies of a stocker made from tubing. the oe lower arm design is fine for what most of us are using our rides for.however the idea of a fatigued lower ball joint location on an 35+ year old arm under my car is enough for me to look for a replacement though.if you're gonna spend your hard earned money on some replacement arms why not do it in the name of better geometry = better alignment.you're on the rite track with the taller bj's and all.
the speedway aren't the strongest items around, isn't designed with longevity/street use in mind either.the only thing the sc&c arms offer is the way it's adjusted.other wise you're using shims instead of turning the turnbuckles.
if you're looking for a good read pick up mark saviskie's book on handling called"how to make your muscle car handle". it's good theory and it covers a lot of what takes place when you use the taller upper/lower joints etc.sure he pushes the sc&c parts( you can apply the math and theory anyways) but still a good reference.you want to find some upper arms that offer increased caster by design and when loaded with a taller ball joints also improved camber curve for better handling etc.as far as which company to go with,do your home work and read up see what the company has to say about what EXACTLY their product has to offer your car.
Reactions: 4 users
Streetbu
Know it all, that doesn't
3,733
11,573
Central NY
Best? I used RideTech front end system and I'm very pleased. They aren't cheap though....
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
PRO SERIES GM G Body Tubular Upper Control Arms
4 times more vertical weld on the mounting plate
Stronger screw in style ball joints
No special tools required
Uses modular rebuildable QA1 Ball joints
Why Modified Front End Geometry is Needed
If you want to improve the handling of your ride, you must first understand what is wrong with the original geometry. From the factory, these cars were designed to understeer. To make them do this, they used a very short spindle with the upper A-arm at a steep downward angle, which results in a backward camber curve making the tires lean out of a turn, using only the edges of the tire. Not only is this bad for mechanical grip, it's also why every stock Chevelle, S-10 or G Body wears the outside edges of the front tires. Below is a diagram of the stock geometry at rest, and then in a hard turn. Notice the severe angle of the tires. All of the cornering forces are placed on a very small area of the tire.​
To deal with this problem, there are several things that will help. Simply lowering the car will help to some extent, but not nearly enough to correct the whole problem. Bigger sway-bars will reduce the amount of bad camber gain, but again, it's not enough... it's like a band-aid on a gunshot wound.
To fix the bad geometry, you need a taller effective spindle height. The "effective height" of a spindle is from the pivot center of the upper balljoint to the pivot center of the lower balljoint. Tall spindles with stock balljoints, or stock spindles with extended balljoint studs will both achieve this goal.
Below is a diagram of the same car equipped with a taller effective spindle height. Notice that the tires remain near vertical using the entire tread evenly across its contact patch. This is key to getting the most grip, and life out of your tires.
FRONT END HANDLING KITS EXPLAINED.
Improve handling and fulfill your rides built-in performance potential by installing our tubular upper a-arms. The relocated ball joint plate on these a-arms permits greater positive caster. Expect improved steering feedback courtesy of increased caster and a precise feel due to the deleted bushings and replaced with roller bearings. Features include grease-able steel cross shafts and improved header clearance. These track-tested, jig built DOM a-arms are supplied with a durable gloss black powder coat finish which guarantees your performance parts stay beautiful on your street car, drag car, autocrosser or Pro-touring machine.
The SSM Stage 1
The secret is the combination of the extra tall ball joint to match your new tubular upper arms which greatly improves the camber curves and relocates the roll center. This means more grip and less body lean. The 1" EXTRA tall upper ball joints reverse the backward factory camber curves for a huge increase in grip. They also raise the extremely low factory roll center to dramatically reduce body roll
For stock and lifted cars this radically corrects poor ball joint angle and helps the arm clear the frame when lifted properly.
For drag racers SSM Stage 1 Plus allows faster weight transfer and more positive caster for better top end stability.
The SSM Stage 2
The stage 2 goes even a step beyond the Stage 1 Plus and further corrects the terrible backward geometry of the factory front suspension, by using Racing Series ball joints, the ONLY ball joints made 100% from US materials in the USA!
They are much stronger, smoother, and longer lasting, than original GM, or any other aftermarket ball joint. The .5" taller lower ball joints further improve the camber curves and roll center location, significantly reducing lateral roll center migration for more predictable behavior.
They also correct the factory bump steer issues by raising the tie rod ends into proper alignment.Now with extremely improved geometry designed for the rigors of SCCA, TransAm and NASCAR your car will truly dominate the street and track!
Additionally, all low-friction ball joints have 32 degrees of swing angle for maximum suspension travel and contain no springs or plastic parts. Dust boots are not included but available.
Changing just the upper A arms can only do so much. The length and offset of the arms has very little effect on camber change, roll center or overall handling. They add + caster which can make the car track straighter at speed and improve turn in. However too much can make the car feel vague and the steering sluggish so that only goes so far. As the + caster is increased there is a tiny improvement in camber as a side effect when the wheels are turned. Our upper arms have this benefit as well as more caster adjustment. To make any profound improvement in the suspension geometry of cars that need it the actual pivoting points (pickup points) that determine that geometry need to be moved vertically. Road race cars like SCCA, TransAm, LaMans Series race cars and fast DRAG CARS use special taller spindles, raising the upper ball joint pivot points like our Stage 1 and 2 packages do. This was the genesis of our AFX tall spindles for the GM A Body platform cars. For years circle track racers that run stock G or F body chassis have used taller truck upper ball joints, which seated improperly to improve the geometry. They’ve been doing this kind of thing for years by fabricating new parts, mixing and matching stock parts, modifying suspension/frame mounts etc. That’s how to win races with a less than perfect factory chassis and a small budget. We’ve taken that race experience, applies new technology and brought it up to date with our SSM STAGE 2 package. Major suspension improvements, not just shiny parts.
Much of it also has to do with alignment. A lot of folks think if their car goes straight and doesn't chew up the tires that it's aligned properly and working as well as it can. They're kidding themselves and they're missing out on a LOT of performance. The alignment specs recommended in the `60s and `70s (and even `80s!) were anything but performance oriented. In fact they've changed little since the 1940s. Today almost every car is using power steering and we're all running high performance radial tires (except for the resto guys but that's another story...) these tires are often more than twice the width of the originals, we've also got another 40 years or so of experience to draw on. What's more, once we've corrected the geometry so that it works like a new performance car it demands the same type of alignment those cars run to achieve peak performance.
Modern performance cars run a LOT more + caster and - camber. The + caster helps the cars track better at highway speeds and gives better steering feel. The - camber helps keep the tire's contact patch flat on the road surface during cornering. It's part of what makes new cars drive like new cars. Using these kinds of settings on older cars yields a BIG improvement in drivability and performance but because they were designed around different specs it's usually impossible to attain the best numbers with stock parts and shims. Lowering the car or increasing the effective spindle height with taller spindles or taller ball joints all add more + camber making it ever harder to dial in a - camber setting (which is what we want). That's the big reason for different upper arms. The taller spindles or tall ball joints make the big geometry improvements and the proper upper A arms make it possible to combine the new parts and geometry with the proper performance alignment, an unbeatable combination!
64nailhead
Goat Herder
Dec 1, 2014
5,692
12,154
Upstate NY
Great question as I'm i the same boat as you - ready to make an upgrade but unsure of which way to go. Price is a concern, but durability and quality are much more of a concern. - but why throw money away unnecessarily?
I've got a set of UMI rear upper and lower control arms as well as an UMI rear sway bar - great products that have stood up. And better than that, when you contact them, they treat you like a human and are knowledgeable and friendly. They are borderline local to me which also makes me want to do business with them as well.
I have no issues with SSP and am presently leaning towards their tall ball joint and upper setup due to both price and no one indicting anything negative about them or their products. But I need to talk to them first. The previous post from SSP explaining the handling improvements is GREAT. But at some point I'm going to be looking for someone to hit me with some alignment specs - I'm yet to see them posted.
Macguyver
GBodyForum Sponsor
Mar 21, 2017
292
458
I have no issues with SSP and am presently leaning towards their tall ball joint and upper setup due to both price and no one indicting anything negative about them or their products. But I need to talk to them first. The previous post from SSP explaining the handling improvements is GREAT. But at some point I'm going to be looking for someone to hit me with some alignment specs - I'm yet to see them posted.[/QUOTE]
Alignment specs have to do with what parts you are using. Static alignment specs mean very little and that changes when you introduce stopping and turning. With mismatched specs and parts weird things start to happen. Provide us with that info and we can "steer" you in the right direction. (pun intended).
64nailhead
Goat Herder
Dec 1, 2014
5,692
12,154
Upstate NY
Your writeup describes every issue I have - funny handling at high speeds - which is the reason for us upgrading. Even at the dragstrip, it's an uncomfortable feeling at 110+. It's the reason for only running 1/8 mile.
I'll be in touch :)
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
I'll be in touch :)
Do you have the caster as high as you can get? I got 3* with no front shims, and it did help.
