Best Throttle Body
MechMan
MechMan
224
Long Island NY
I am looking for a 90mm throttle body for a LQ4 swap with L92 heads and the LS3 intake. I want to keep it drive by cable and so far i have seen the Holley sniper but it looks like you have to use their IAC and TPS. Anyone use this product or is there one that you all can recommend?
motorheadmike
motorheadmike
3,911
Ottawa, Ontario Canada
Warr Performance.
Reactions: Injectedcutty
MechMan
MechMan
224
Long Island NY
I only see 92mm from Warr Performance. I was looking for a 90mm will it make much of a difference if i use 92mm?
motorheadmike
motorheadmike
3,911
No. It is a c*nt hairs difference. I have one on my ported TBSS intake, and I am ordering another for another stock TBSS intake.
Reactions: fleming442
MechMan
MechMan
224
Long Island NY
Whats everyone's thoughts on the PCV? How would you run? With it or use a breather?
motorheadmike
motorheadmike
3,911
Why wouldn't you use it? Look at my wagon's LS1 - it has a fully functional set of emissions controls.
MechMan
MechMan
224
Long Island NY
You can but the throttle body either with or with out the vent tube. Was wondering wich one to get.
motorheadmike
motorheadmike
3,911
Warr Performance
That is a different question. I have one without and had to source the fresh air forward of the TB but behind the MAF because it is metered air, and as part of a closed loop system it must be pulled back around through the crankcase and back into the intake. Mine comes out of the valley cover PCV into a catchcan.
MechMan
MechMan
224
Long Island NY
I also just relized that there is no cable braket for the LS3 intake. Anyone know of where to get one that will work?
motorheadmike
motorheadmike
3,911
Use the truck manifold and adapt one like I did. It is a better intake anyway.
Thread starter Similar threads Forum Replies Date
Stupidquestionspro Fuel / Air / Boost / Emissions 13
