Betsy sick!!! 81 Buick Regal
Dsmooth7
Dsmooth7
10
Pasadena California
Freeze plug got messed up, water got into my head so changed my head gasket and all of my motor seals, new radiator, spark plugs, water pump, filters, new carburetor, and hoses. Now my temperature gauge is not reading need some help any advice?
pontiacgp
pontiacgp
blank
Mar 31, 2006
28,241
Kitchener, Ontario
I assume you have the wire connected to the sender. Did you put teflon tape on the sender when you installed it?
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,007
Socialist NY
Didnt see oil listed hope you changed that!!
V
vandyman
29
8
Make sure you have a good ground on the motor.
Do not put any tape or sealer on the sending unit, the sending unit needs a good grounding from the motor to work.
Gonzo1970
Gonzo1970
823
The connector on mine had corrosion.. I put it on and got no read. Took it off, cleaned it up a bit along with the end of the sending unit, put it back on and its been great ever since.
(Senders are like... $8 or so)
-Gonz
