BETTY RUMBLE - '87 Cutlass
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,449
4,735
Rolla, MO
Well I've had the car for a few weeks, put a few hundred miles on her. She's reliable if nothing else.
img_3212-jpg.44184
img_3215-jpg.44187
This will be my "master checklist" for the car. "Project Blue Book" she will be known as, here and on GBodyMag.com ... I still haven't come up with "a direction" for the car, but I know there are things that have to be done, and things I'd like to do, not in any order really... some easier/cheaper than others... Some very minor, some not so much... So here we go. I'll move things around, add/remove things at random, and strike them out when they're done.
Oil Change done 10/30
plugs & wires (8/25/17)
front/rear shocks (bought, fronts done Nov.)8/17
intake gaskets leak (bought)
valve cover gaskets leak (bought) (hope that fixes oil leaks?)
check brake pads/shoes (all feels good, but just bc) yeah good
Trans fluid/filter change (yuck) + fix TC sol. + 4th PS
pcv/breather (8/10/16)
once-over on ALL hoses, vac lines, and wires
distributor/cap ?
2" lowering springs/shocks (Thank you UMI Performance, have in hand 8/16/16 done 8/28/17)
rear sway bar (done)
bigger front sway bar (I think I have one?)
interior courtesy lights don't work (upgrade to led? I have a dual map light somewhere too)
(found the foot-light sockets! done 9/4/16)
reglue/replace headliner
upgrade to gauges (completed 8/24/16)
rebuild steering column (loose tilt, wiper switch sleeve busted, rag joint)
rebuild front suspension (upgrade time!) done 8/28/17
rear diff cover gasket
almost inaudible lights-on/left-yer-keys beeper
upgrade headlights/tails all ext. lights to LED (properly)
--- sort-of finished with issues 9/4/16
442/Hurst cat-back dual exhaust (7/29/16)
driver-rear wheel well trim mangled from blown tire
window tint
cruise control INOP (removed, not original, 8/17/16)
windshield washer INOP (new pump, 8/31/16)
replace ugly steering wheel(!)
left channel audio INOP, replace/upgrade unit (has 4 speakers tho)
(7/22/16)
replace busted PS front grille
upper door panel vac-chrome needs attention
remote PS mirror
power locks?
power trunk button/latch
carpet?
underhood/trunk lights
lower door panel courtesy lights
power window motors are dog slow, probably need replacing eventually
window felts/rubbers/stops
front bumper corner trim mounts are bent "out"
weather stripping, doors, windows, trunk (8/24/16), cowl
speedo cable (rattling/gauge flutters)(8/21/16)
glove box rattles :mad::mad:
speakers/amp?
fuel sender/tank unit... (put 13 gallons in today, gauge said I was down to 1/8....)
passenger-side AC vents broken
rear bumper insert chewed up from bent license plate/gas cap access :mad:
wish list:
eventually upgrade to olds 350 or 403, but want to keep all the "junk" running smooth if possible. humor me.
install "GN-ized" 200-4r
rear end/gears
buckets/console/floor shifter?
wheels/tires (DONE 8/12/16)
442/Hurst spoilers front/rear
PAINT (remove aftermarket vinyl top)
Blazer brakes/spindles
It's funny because there are things on this car I never even knew existed. i.e. cardboard(?) covers over the control arms in the engine bay, "splash guards?" over the wiring for the front bumper parking lights, a few other "huh. look at that." things. I need to get the parts book for this just to see what was available.
  • Winner
Reactions: 6 users
1evilregal
3,057
4,355
Greensboro, NC
nice lookin ride, feel good to be behind the wheel of a g-body again?
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,449
4,735
Rolla, MO
It does. Makes me want to get the GP back from the dead even more now. Anyone know how to clone a person?
8,456
7,148
Melville,Saskatchewan
Long list but it is nearly 30 years old. I too have those fancy splash guards for my front signal lights.
liquidh8
13's huh? :rofl: lol. Looking forward to this. I have front and rear swaybars too if you can't dig yours up. Probably would stink to ship though.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
11,882
9,225
Gainesville, Fl
You have quite a check list there, Chris. It certainly is a nice clean looking ride. Well worth the attention you give it. ;) BTW, the name that was given to the project is appropriate.
Rktpwrd
Builder of Cool Shjt
3,980
22,419
Calgary, Alberta, Canada
I'm glad y'all like the name, as I was the one responsible for suggesting it be dubbed that. As Jack mentioned, it just seemed appropriate.
Longroof79
Oct 14, 2008
11,882
9,225
Gainesville, Fl
Donovan,
'So you were the one that actually dubbed this project "Old Blue Hair"? ..very clever on your part.
Rktpwrd
3,980
22,419
