Big block heads on a small block?
Big&Rich$
n00b
Jan 22, 2017
4
2
I've read it can be done in several different articles. My question is which intake do you use when you make the head swap? My 86 Cutlass Supreme has a 71' 350 in it. So 455 big block intake or small block intake when you do a big block set of heads on a small block olds.
JAMCAR223
1,853
5,507
Houston, TX.
You use the small block intake and port it to correct the mismatched port alignment of the 455 heads.
Bar50
1,180
870
Tulsa, OK
You really need an intake that has enough meat to port to big block Olds size...some of the Edelbrock intakes are made that way.
565bbchevy
9,591
12,612
Michigan
If you use the cast iron 455 heads the Edelbrock Performer RPM #7111 has enough material to port match but being that your name is "Big&Rich$" why not just spring for the Edelbrock aluminum heads and save some weight and have a better flowing head.
Kennybill
286
401
Braceville, Ohio
Do you have the big block heads and if you do, what is the letter on the corner before #1 spark plug hole? What "number" are on the small block heads on the engine presently? Stay away of J big block heads. You may lose a little compression unless your your small block heads are#8's which are around 80ccs like BB heads.
Oct 14, 2008
8,806
7,746
Melville,Saskatchewan
Either Procomp or Edelbrock heads with 10 cc's removed and the #7111 intake. Your 71 350 has huge dish pistons and will need replaced. Your #7 heads are good heads to start with and unless 10 to 1 compression and a big cam is used, I would just open the bowls and add 2.07"/1.625" valves on the factory heads.
