Bilstein shock differences?
clean8485
2,862
2,153
Ontario, Canada
I'm looking at getting Bilstein shocks for my Malibu. As I look at the listings for these shocks, there are 2 different types listed. 1 is a heavy duty, and the other is called the AK series. The heavy duty prices at about $15.00 more per shock. Does anyone know if there are any major differences between the 2 types? Is one better than the other? Thanks in advance.
UNGN
3,048
3,264
Southlake, TX
Generally one is valved for comfort and other for sport. It is basically the difference between a GN and a pillow roofed velour bench Regal.
If you push on the fender of a car with comfort Bilsteins, its like a fluffy cloud. If you push on a fender with sport bilsteins, it pushes back.
My XJ8 Jaguar has Comfort Bilsteins, my XK8 Jaguar has sport Bilsteins and the difference is night/day in feel when you push on a fender.
20,391
the Bilstein heavy duty is a self adjusting shock, the AK series is linear. With a linear shock you know the compression and rebound rates.
20,391
One other thing with the AK series is they have a stock length and a short version
clean8485
2,862
2,153
Ontario, Canada
Thanks Mike. I'm working with the old cast iron small block. I put Bilsteins (can't remember the number now) on my Monte SS, and I'm very pleased with the results. The description that I read between the 2 different lines of Bilsteins was kind of vague, so I was trying to see if anyone could provide some more details. Thanks for the link to your thread.
Doug Chahoy
2,565
2,662
I'm planning on going with Moog 5660 springs suggested in an early thread. The HD Bilsteins I was looking at say they are for use with stock springs. Will this combo work?
clean8485
2,862
2,153
Ontario, Canada
As long as the 5660 spring doesn't go above the stock ride height, it should work. The 5660 springs that I'm going to use have had 1 coil removed.
