So I have been driving myself nuts for the past few weeks. I have a no start no crank situation. If I turn the key to the on position the lights work, dashboard lights up, fuel pump turns on etc. The battery is brand new and holds a charge. So I thought it might be the starter. I changed the starter. Put a test light on it, there is power going to the starter and solenoid. The ground is also good. So yesterday I finish up the installing the new starter and go to start the car and BOOOM cranks right over and starts. Today I go back into my garage go to start the car and same thing happens. No start/no crank. The lights work, dashboard lights up, fuel pump turns on, battery is charged. I crawl under the car with the test light and the starter and solenoid are getting power. The ground is also good. So I'm stumped. I tried to start it in both park and neutral and that does not work. The only thing I can think of is the ignition lock cylinder needs to be replaced. Curious to hear what everyone thinks.
