hello all
Ever since I did the blazer swap I have been having an issue where from time to time My brake pedal would go all the way down and come back after Released. Thinking it was air, I bleed the living day lights out of the system with no result. I finally think I found the issue. This only happens when i turn my wheel all the way in either direction. So I believe my brake lines are too short. My lines are stock but I also have bell tech drop spindles. I know this swap has been done a bunch and haven’t seen anyone with the same issue. I would think the drop spindle would have brought the caliper closer to the line making it a lil longer, any other ideas would be appreciated. Does anyone make a little bit longer front brake line?
