Hello Everyone,
I have finally located a pair of 2002 Blazer spindles, for my 87 442. I have read on the forums, that you can use the existing Brake hose to the caliper as per https://gbodyforum.com/threads/98-05-blazer-brake-upgrade-done.35747/ ( Great write up)
I know that if i go with the Blazer hose, i need a fitting to convert from 7/16"-24 to 3/8"-24 (Fitting part number Edelmann 258340 or equivalent)
But after researching i found this:
Part number: Dorman H36847
Overall Length: 11.88"
Fitting Connection: 3/8"-24 to Banjo 10mm
Part number: Dorman H381342
Fitting Connection: 7/16"-24 to Banjo 10mm
Part number: Dorman H381064
Overall Length: 12.25"
Since i need new hoses, could i just order the rear Blazer hose (P/n H381064) ? It is the same fitting as the stock G body, and you get an additional 0.37 inch.
Could this work?
Thanks in advanced.
Could this work?
Thanks in advanced.
