Blazer brakes dust shield and hose questions.
19,992
Warning: Just leave your stock factory G body brake hose brackets installed. The Blazer brackets contacted my 15" wheels at close to full steering lock! I re-installed the G Body Brackets and problem solved!
I think you are the only one that ever had that issue.
What is your wheel backspace?
19,992
Will hose brackets from a 4WD Blazer work? The brake set I bought did not have the frame hose brackets, and 2WD Blazers are scarce in my area. None of the local junkyards have 2WD models.
I believe so as long as they point downward like in my picture
abbey castro
1,048
1,317
Harker Hts TX
I have done this conversion.
1. The same year Blazer 2 wheel Drive brake hoses are a direct fit, no mods required. NO adapters or brackets needed. I have pics picture if anyone say other wise.
2. The dust shields are not needed. At first I did not have them and everything fit. I decided to buy new ones at Rock Auto and put them in strictly for appearance sake.
3. Rears done too w/ F Body Disk Brake proportioning valve (2002 Camaro Brakes)
12,175
9,777
At first I had a bit of a clearance issue turning the wheels to lock on one side. I also used the Blazer hose brackets. I had to bend them in a bit to make sure they fit right against the frame. I also used the braided Russell brake hoses which are thinner than the Blazer or G-body hoses. They seem to conform well, but I'm not thrilled with their fittings. The stock Blazer fittings seem to feature a lock system (against the caliper) that helps retain them from turning.
One bracket scraped against the tire. No clearance issues with my 15" steel rims.
19,992
I have this on both my Malibu and Cutlass with zero issues
12,175
9,777
Just wanted to clarify my statement: The blazer bracket contacted the side wall of my tire at full lock , not the steel rim.
One of mine also contacted the sidewall of one tire. After taking the wheel off, that's when i noticed that the brackets stuck out a bit. I then removed them and bent them closer to the frame. Seems like no more issues with tire scrub.
ItsnotaGN
662
1,142
Colorado
Went to the pick and pull yesterday, got my calipers of a 4wd blazer, with brackets they cost me a whopping $22 bucks. I didn't bring a socket to get the hub nut off, so no dust shields. Rockauto lists the dust shields for $33 bucks apiece, Mr. Cheap will be revisiting the boneyard for the dust shields today.
