Blazer front brakes question
gsbuick65
n00b
Jul 25, 2021
2
im restoring a 87 GN and changing the front spindles over to Blazer, has anyone found non abs wheel bearings?
oldsmobile joe
1,752
mpls
no. why?
JAMCAR223
1,711
Houston, TX.
I assume he's worried about leaving an open hole for water/dirt after removing the ABS wiring? If so, just remove the ABS wiring from the hub, and purchase the blockoff plates from Riffraff Diesel.
oldsmobile joe
1,752
mpls
I just cut the wiring off and applied some black rtv to keep the water out.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
11,341
Gainesville, Fl
That's pretty much what I ended up doing. However, I think the Riff Raff diesel fixtures are pretty slick.
gsbuick65
n00b
Thread starter
Jul 25, 2021
2
Was just wondering, so there wouldn't be a hole, I just black rtv'ed the one that was good, I'll check out the plates
Longroof79
Oct 14, 2008
11,341
Gainesville, Fl
I actually greased mine prior to reinstalling the plugs.
64nailhead
Goat Herder
3,290
Upstate NY
Or put a sensor in there so that when you swap over to an aftermarket ECM you can use that sensor and rear axle/speedo output/driveshaft sensor for traction control ;)
G-Body Performance Upgrades
