Blazer front brakes question
gsbuick65
n00b
Jul 25, 2021
2
im restoring a 87 GN and changing the front spindles over to Blazer, has anyone found non abs wheel bearings?
oldsmobile joe
2,067
3,053
mpls
no. why?
JAMCAR223
1,853
5,507
Houston, TX.
I assume he's worried about leaving an open hole for water/dirt after removing the ABS wiring? If so, just remove the ABS wiring from the hub, and purchase the blockoff plates from Riffraff Diesel.
oldsmobile joe
2,067
3,053
mpls
I just cut the wiring off and applied some black rtv to keep the water out.
12,174
9,776
That's pretty much what I ended up doing. However, I think the Riff Raff diesel fixtures are pretty slick.
gsbuick65
n00b
Jul 25, 2021
2
Was just wondering, so there wouldn't be a hole, I just black rtv'ed the one that was good, I'll check out the plates
12,174
9,776
I actually greased mine prior to reinstalling the plugs.
5,695
12,175
Or put a sensor in there so that when you swap over to an aftermarket ECM you can use that sensor and rear axle/speedo output/driveshaft sensor for traction control ;)
