Blazer Spindle Oddity
bs009
122
232
Smashville
Hey, been a long time since I've posted. Will probably do a introductory thread someday because I have a lot to show off now :LOL:
So I swapped on Blazer spindles on my GP a few years ago and installed a bump steer kit recently. I was about to work on doing a initial alignment for it when I noticed that there's different clearances between the passenger side and the drive side tie rod end mounting points compared to the wheels.
I'm assuming this isn't normal right? Maybe I just grabbed the wrong passenger side knuckle when I did this a few years ago? Or maybe it was bent on the truck it was pulled from?
Wheels are both 16x8 IROC fronts there in those pictures
Streetbu
Know it all, that doesn't
3,733
11,573
Central NY
Yeah, somethings not right. I'm guessing the left side spindle is bent.
Squag27
33
17
8
West Palm Beach FL
Those are definitely both 2WD spindles. Looks like the driver's side is bent as the top of it where the tie rod nut sits is at about a 15 degree angle on the driver's side and pretty much horizontal on the passenger's. I'll have to take some pictures of my blazer spindles when I get home for comparison.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
It does look bent the more I look at it. Yeah, the 4WD spindles won't work.
bs009
122
232
Smashville
So I was going to just order a new passenger side spindle but it makes sense now that it's the driver side that's bent like you've all said. For sure they are both 2wd spindles since there's no pass through for the cv joint behind the wheel bearing.
The passenger side tie rod nearly touches the wheel and the driver side has almost 2" of space there.
I'm going to make a junkyard run this weekend now, looks like there's a few 2wd S10's in the local yard that I can pull a knuckle from. I'm thinking of just grabbing both sides just in case the truck I pulled it from was fubar and both are slightly bent.
Glad I caught this before I went and had an alignment done though
JAMCAR223
1,853
5,507
Houston, TX.
Just remember that S10 will not work. If you meant Blazer, my apologies. 1998 -2005 Blazer is what you are looking for. I have pair now if you don't find a set locally. I can ship them Thursday or Friday.
Reactions: 4 users
bs009
122
232
Smashville
Didn't realize there was a difference between them, looks like the s10 spindles are exactly the same as the g-body OEM spindles then, crap
There is one 2wd blazer in the local LKQ but it's been in an accident so it's possible it's pretty messed up too. Found another yard though now that has 8 blazers, but no information about them aside from a front end picture. 2 of them have a front angle picture showing a cv joint shaft so it looks like there's 6 left to look at.
Seems like ordering online is going to run me ~$220 after shipping compared to $80/set in the local yards. Might order a set just for insurance in case the yards don't have what I need, I'm leaving for Power Tour on Friday next week so I have to have the car ready by then.
Squag27
33
17
8
West Palm Beach FL
Check FB marketplace or Craigslist for parts cars too. That's where I found my set. Also as promised here are the pics of how mine sit. You can see that both sides are pretty flat at the tie rod nut mount.
JAMCAR223
1,853
5,507
Houston, TX.
I thought most people on the forum knew I usually had these for sale. I have a pair in stock, and got him fixed up (y).
  • Winner
Reactions: 7 users
