I have found a bunch of "options" for the bleeder screws. I want to have it 1 and done. I have a 1978 Pontiac Grand Prix SJ with disc fronts, drum rears. The front driver hard line from the distribution block (or whatever) blew out, thankfully in the drive way, and I went through the absolutely most enjoyable time removing the fitting, which I stripped instantly, bending a new hard line and putting it in. Went to bleed the brakes and despite hitting the bleeder screw multiple times with a variety of penetrating oils, it stripped then finally sheared off. I am going to get it out somehow, but I obviously need a new front bleeder, and since the reservoir appears to have the original fluid, I am flushing the system, so I need the two rear bleeders and the fronts.
What size/part/whatever are the front caliper and rear wheel cylinder bleeders? Any recommendation on brands?
